How to test overheat alarm?
Andy in NY
motor is a 1966 500. Last weekend while working on it, I noticed that it was not peeing and the telltale hose was pretty hot, as was the motor. No alarm ever went off. How can I test it?
jimg984
Re: How to test overheat alarm?
no alarm for that year model unless one was added after mfg
Andy in NY
So then how would I know if it suddenly stops cooling?!?!?
electricjohn
That's why it was originally called a "tell tale".
Chris1956
Andy, You can install a water pressure gauge on the dashboard. On those old inline motors, the water pressure was neve more than 15PSI, so choose one with a 0-15PSI scale. You will likely need to tee it into the telltale hose.
jimg984
telltale hose is a open dump no pressure there
Chris1956
jmg, Telltale has pressure, which it does more than dribble out at cruising speed. The block has pressure too, and if you screw a brass tee into the hole the telltale elbow was in the presure gauge will get a reading.
