Is there a flush/test connection for a hose that I can't see?The only water inlet I see is on leading edge of lower exhaust - doesn't look amenable to muffs etc
Take a large garbage can and fill it at least half full. Hang the motor on it (making sure the water is above the cavitation plate) and you can run the motor at idle speed. Water muffs won't work on your motor.
