How to test stern lights
Gradywhite3535
My light at the stern isnt working. I dont know if the bulb needs to be replaced or if the wire or switch is messed up. What should i do?
tpenfield
Re: How to test stern lights
Replace the bulb :noidea:
then if that does not work . . . go for the switch.
Don S
Man, you really need to get a book and learn about electricity and how things are done on boats. You have a thread on books, http://forums.iboats.com/electrical...lectrical-books-market-these-days-590436.html and you also want to add LED lights and do all sorts of things. To do all that, you have to know what you are doing or you're just going to end up with a boat I have seen too often in the shop. Wiring so messed up it can't even troubleshoot it. Too many off the wall splices, color changes, Scotch Lock connectors and all.
Don't be one of those guys, get your book and study it before you do anything on the boat. Then figure out what you want to add, or fix and go from there. You are all over the map with questions, but you never follow up with an answer on any of the questions you ask, you just move on to the next question...........
Gradywhite3535
I want to test this light, can someone help me. I changed the bulb and still work.
mxcobra
You need a volt meter to do testing, one wire is power + one is a ground -.
+ supplys the power
- runs throgh every electical item on your boat from engine to well everything..
that light needs 12 volts to work.
if its not getting 12 volts then find out why not either wire or switch?
Gradywhite3535
I havd read a book but it doesnt explain how to unhook this light so j can get to the wires
gpfishingdude
You need to find if you have voltage at the socket or at the wires leading to it. They make 12 volt testers for this. Or you can take a VOM and turn it to 12V and and touch the contacts on the socket to see if you are getting 12 volts- the side of the socket might be the ground- If you don't get any voltage try the wires between the switch and the socket to see if the socket is bad. Then if you still don't have voltage try between the battery and the switch. If you have voltage there then the switch is bad. Otherwise you have a bad connection at the battery or where ever the wires from it are connected. This shouldn't take very long with a tester and make sure to flip the switch on before you test to make sure the circuit is live first. Most of the time the problem is a bad ground so you have to make sure that everything is grounded like it is supposed to be. I think on boats that everything is grounded back to the battery.
mxcobra
Pull the screws that hold the socket 3 of them probly philups bit. Looks preaty rusty you may have to drill them out. the wires dont unhook you will have to cut them.
Alwhite00
Stick the tester in the socket on the terminals to see if you are getting 12v - Did you check all the fuses?
LK
Silvertip
Lets try a little logic here. If a table lamp in your house doesn't turn on when you hit the switch what would be your first inclination?
I think 99% of the population would try replacing the bulb just after glancing at the power cord to make sure it is plugged in don't you think? If that doesn't work you DO NOT start replacing things -- you begin troubleshooting. For 12 volt circuits all you need is a test light (about $5.00 or less) for basic testing purposes. If the bulb has been replaced and when you did that, you also looked at the socket to see if something wasn't wrong in there, then turn on the switch. Connect the ground lead for the test light to ground. Since you have limited electrical knowledge, that would be the negative terminal of the battery or the ground buss connected to it. Using the probe, touch it to the input (the LINE side) of the switch. This line comes from the fuse panel and provides 12 volts. If the test light doesn't light, move backward to the fuse panel and check for power on that fuse. If you have power at the panel and not at the switch - you can draw the conclusion that the wire is broken or disconnected at either or both ends. No power at the circuit side of the fuse says -- hey -- check the fuse. If you have power INTO the switch, check the output (LOAD) side of the switch. If you have no power there the switch is bad. If you have power there, check at the center terminal on the light socket. If no power there you can reasonably assume the wire between the switch and the light is broken or disconnected at either or both ends. If you have power at the socket there is a bad ground wire connection. So the short answer to your question is Yes -- it may be the bulb, the wire, the switch or lack of 12 volts to the circuit. But as others have suggested, you really need to get some Low Voltage 101 education if you intend to install or troubleshoot boat electrics.
Gradywhite3535
The socket seems to be in good condition. How can i test the voltage. I have a multimeter anc light test. What could i use as a ground? One of the 2 prongs or the sides of cthe socket?
Don S
If you have two pins in the socket, one is hot, one is ground. The case is nothing.
attachment.php
Silvertip
Ground is wherever you find it but it is ultimately the NEGATIVE battery terminal. Any wire or buss connected to that terminal is "ground". You can use a test light for testing. Ground to ground, probe to the hot side of the circuit. If you use a meter, set it to the 20 volt scale and connect the black lead to ground and probe the hot side of the circuit with the read lead. You still have not answered the question about WHAT DOES WORK and WHAT DOESN'T work on this boat. If the fuse panel is dead no amount of testing of the anchor light will prove anything except that it doesn't work. Here is a diagram of how current flows through a circuit. follow the arrows and pretend the lights are any device you please. Current doesn't care what it is powering. Wiring is basically the same for simple circuits. If you do a search in this forum for NAV/ANC switch wiring you will find many posts on this topic with applicable diagram.
Gradywhite3535
Are multimeters from harbor frieght any good? The brand is centec, i use it today and the reDings were all over the place
Gradywhite3535
And my test light has alligator clips so i cant get to the probes on the socket. All fuses are good and so far the 2 spot likes work by pulling the swich and bilige pump works with a switch. Thanks for helping out as iam trying my best to understand electrical systems. I have bought another book anc waiting for it.
Don S
Clip a small drill bit into the clip of your test light, much easier to use than a meter. Plus the bulb from the test light puts a bit of a load on the circuit.
Just check the battery with your test light first to see how bright it is, if it gets dim along the way, you have high resistance in the wire or connections, a meter would just show voltage.
gpfishingdude
The alligator clips are on the ends of your testers wires. You can clip a small sharp nail into the alligator clips and then wrap all but the sharp end of the nails in electrical tape to make sure you don't touch the nails together and get false readings. You have to be careful that you just touch the contacts down in the socket and the contacts on the switch too when you are testing them. If you want to test the wiring in between anywhere along the circuit you can prick a wire with a nail and test that way. Do like Sivertip says and just follow the wires and test one place at a time until you find where the circuit is open. Extend your probe wires if you have to by clipping them to some extra wire if you have to.
