How to test your Transom
wreckingball
hey guys,
new to boating so bought a 1988 Grew and as i was cleaning our the junk noticed that behind the steel gas tank there looks to be some dry rot on the wooden transom. what do you guys think and how can i test it ? also the paint or fiberglass is coming off the wood
MTboatguy
Besides being a 1.5 mega byte image that took forever to download, I don't think much testing is required, that one needs a "wreckingball" and replacement!
:lol:
CrazyFinn
That photo is all the test you need. New transom required... probably the same for any other wood in the boat (floor, stringers, etc).
wreckingball
ok thanks, anyone what the approximate cost might be for a transom repair? also you mentioned "stringers" not sure but my floor is full cover with fiberglass
CrazyFinn
Most fiberglass boats have a series of stringers that run forward from the transom under the floor - they provide rigidity for the hull and support for the floor. They are usually made of wood, encapsulated in fiberglass. The floor is also wood with fiberglass on top. Most boats also have the empty space between the hull/stringers/floor filled with foam for flotation.
The problem is that most boats are built with an expected "trouble free" life of 10 years, maybe a bit more. Just like your car, they are not built to last forever. That doesn't mean you can't make them last forever, but it requires maintenance and repair.
Boat factories are not very good at making sure that water can't get into the wood/foam eventually, and a lot of boat owners don't help the situation either.
Once water makes it's way into the wood via a crack, screw hole, etc., rot begins. Eventually, it takes over. The wood gets waterlogged (and heavy). The foam under the floor gets waterlogged (and even more heavy). It holds the water against the stringers and floor - and eventually the water makes its way through everything and it all just rots.
There are plenty of threads on these forums showing what is probably under your fiberglass. Take a look at both of my threads in my sig below (different boats than yours, and older, but the problem was the same).
Cost will ne about $2-3k....and more if you have an interior.
Expext to put about 200-400 hours of work
Good read is link 14 in the DIY stickies at top of the forum
sheboyganjohn
From what you have posted, it almost looks like you may not have stringers, or at least in that part of the boat. If that is the case, you are just doing a transom and an interior, which will reduce the cost and time by at least a 1/3. Need a few more pic's of the rest of the inside of the boat to be sure.
