Clark Savage Jr
Thread starter- Joined
- Mar 1, 2011
- 14
Until I can get my grubby little paws on an owner's manual, will someone be kind enough to tell me the procedure for tilting this engine?
I see the "Lock-Release" lever under the steering rail and it flips easily. The lock is raising as designed. Standing behind the boat and lifting outward and upward by grasping the skeg doesn't tilt the motor. It acts as if it's solidly locked down. The steering, by the way, is as smooth as apple butter and well-greased.
I also see an unlabeled handle on the port side of the motor about 6" long or so. This handle moves easily, but I can't see what it is doing down in the mechanism. Moving it one way or the other does nothing to affect the tilt.
From what I've read, I guess it could be corroded in the down position, but if so, it would be the only thing on the motor in that type of disrepair (except for the front cowling latch - that's rusty and hard to turn). Everything else seems to be well-greased, and it's been stored indoors for six years. The crank turns freely and as I insert a bit of Seafoam into the cylinders, the compression is coming up nicely.
But, this tilt thing has me stumped! I haven't tried removing the tilt stop pin, but it looks like it will slide out freely. Maybe a little Kroil will be needed, maybe not.
Anyone? Please?
Anyone? Please?
