How to tilt 1985 9.9??
Evinrudej
Hey guys I know this may be a stupid question but how do you tilt a 1985 evinrude 9.9. I believe you flip the lever next to the gear linkage upwards and then after that I’m not sure what to do? Thanks
oldboat1
Have it on a stand/boat transom? Tilt pin needs to be in place (the rod and clip that you use to adjust the trim). When you lower the tilt and reverse lock lever (plastic handle -- sounds like you found that OK), a spring controlled locking lever clamps to the tilt pin to keep the motor from swinging up when in reverse. Raising the handle should release the lock so you can tilt the motor.
Springs and the rest of the mechanism under the stern brackets corrode or rust, and that can be a problem, particularly in salt water. In addition, there is a shallow water drive bracket under there that sometimes hangs up. Try oiling up the mechanisms, and check for corrosion, damage, etc.
Evinrudej
Thank you I figured it out doesn’t look to rusted either so everything should be good !
