Re: How to troubleshoot esa circuit
The grey wires are tach input and esa output. Reconnect the grey wires to coil and disconnect the esa output plug, does boat run? If no tach or wiring shorted. If yes then reconnect esa output and disconnect esa input, does boat run? If no esa is fault. If yes switch is fault. Good luck
