how to turn on transom shower 228 lxi?
jshaver2121
I just bought the boat last week, however I was not shown how to do this. I wonder if it is broken.
I have flipped every switch and can not hear the pump turn on.
Any help would be great. I know the dealer replaced the acc switch and wondered if they had left it disconnected, even though the depth gauge is working from that switch.
Thanks
John
Josh1121
Re: how to turn on transom shower 228 lxi?
Had the same problem when I picked up my 248 a few weeks ago. The acc switch in one direction turns on the depth finder, other way turns on the pump. Push the lever on the shower, vacuum turns it on. My pump was burned out and had to be replaced. I would disconnect the pump and see if you are even getting power to down the line, then go from there.
kcadrenalin
I have the 218 LXI (2009) and the switch is right below the steering wheel on the right hand row of switches. It's marked shower. It's the last switch in the row. I can tell you that mine is pretty quiet so you may be turning it on without knowing.
I can take a picture this weekend if that will help.
