Re: How to un seize a 65 chevy 327 v8
I was thinking pull plugs look for rust add ATF AND ACETONE let sit try with breaker bar on crank nut. They said it just had been siting up but ran fine before. Hopefully that will do.
I noticed that you are aware of the superior effects of the ATF/acetone mix for releasing 'stuck' parts!
From a machinist's magazine bench test:
Penetrating oil ..... Average load*
None ............ ......... 516 pounds
WD-40 ............ ...... 238 pounds
PB Blaster ............ . 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of
50 - 50 automatic transmission fluid and acetone.*
Happy boating!
