How to unfasten shift rod from motor on 89 Johnson 60 hp 3-cyl (Model J60TLCEA)
PPP
My Clymer manual is not specific as to how to undo the shift rod from my motor so that lower unit can be removed. I have done this before, had to remove a bolt on left side of motor (looking from rear) that is almost impossible to reach. I have been told that there is a much easier way. Can anyone tell me how? Also, using muffs, do I need to be concerned about how much water pressure is turned on to start and run the motor?
patrick4266
Re: How to unfasten shift rod from motor on 89 Johnson 60 hp 3-cyl (Model J60TLCEA)
That bolt is not all that hard to get to. Take off the bottom carb, then use a 7/16 socket with a swivel and extension. Take out the bolt and pull out the pin that go's through the shift rod. Yes you should be concerned about the water pressure.
Sixmark
Master Chief Petty Officer
In many cases it's not even required to remove the carb, using a 1/4inch drive ratchet and extension with a swivel anda short socket I can remove the bolt without needing to remove anything near it.
patrick4266
Your right about that but I figured it would be easier for him to remove the carb.
