how would you fix this bow eye*pictures included"
bamajoker
this is the bow eye hook, it has a fiberglass patch over it
i looked fron the inside in so look like its all the way through
but when you winch the boat down they eye moves a little bit
i want to get it back to looking normal lol the boat is white.
how can i fix this?
solar7647
Re: how would you fix this
Remove u-bolt
Sand the the patch so that it is flush and can be covered with gel-coat or epoxy.
Remove wood block that bolt goes through on the inside of the hull
Sand the fiberglass on the inside
Add another patch on the area on the inside as it should have been in the first place
Cut a new block of wood and resin it into the hull where th bolt comes in
re drill the holes and install a new bolt and torque it down so it has no movement.
Just MO on how I would do it. What was the damage do you know. Looks like ether the fiberglass was added because the bolt was loose and someone did it to get it to stop moving or someone damaged it by cranking the hell out of the winch.
bamajoker
they guy was loading the boat with the roller half gone, hitting the damn bolt.
bamajoker
how do i resin the block of wood into place?
bamajoker
Re: how would you fix this bow eye*pictures included"
any idea of a materials list of the stuff i would need to complete this project?
this is a 18' bumble bee bass boat by the way.
Shife
I suppose an 18 inch boat would be appropriate for a bumble bee.
i'll get my coat...
bamajoker
rofl so true i was half asleep lol
solar7647
Well you can use a heavy construction glue made for out doors, but since you will most likely be doing fiber glass and will have resin, mix up a few onces of resin and add some saw dust and steer....you dont want a past but just thick enough so its not runny any more. then spread it on the wood plank and stick it in place. You will wont to try and apply some force to it.
You are going to need a fiberglass repair kit, a gel coat repairs kit, prob a new u- bolt, sone acitone, sand paper, rags.
You should be able to get it all at a local marine store. The fiber glass repair kit is also at Walmart and if boating is real popular in the area Walmart may have everything you need.
