Donzi GT250
Thread starter- Joined
- Apr 22, 2011
- 110
I just had the u joints replaced on my 1989 5.7 cobra.
And yesterday after getting the boat back in the water after the u joint replacement I now have a howl coming from what sounds like the drive.
This howl starts abruptly at 850 rpm and seems to fade at around 1100 rpm.
I didn't have this howl before the u joint replacement and when I had the u joints replaced the mechanic said he checked the gimbal bearing and it was greased well and all was OK as he said it was dry in the bellows.
If I put the drive in neutral and run the engine in the rpm range that causes the howl it doesn't make the noise. So the noise is only when the drive is in gear.
Any ideas?
Any ideas?
