hp rating by heads or the carbs??? help please!
xtremefisher1
i have a 1963 40 hp rude model 40353d and a 1965 33 hp 33552 i want to take the carb off the 33 since it has adjustable high and low speeds and an electric choke that i want to put on the 40 hp motor.
1. is the hp rating on the carbs or the head?
2. if i do change them will it make my 40 hp a 33 hp???
any help at all is great
Chinewalker
Re: hp rating by heads or the carbs??? help please!
The 33 and 40 are different displacement, so that's where the extra power comes from. A larger venturi carb may be part of the package, too. Certainly won't hurt to try the 33 carb - may have to richen up on the needles a bit. Check the venturi diameters to see if they are close...
xtremefisher1
without taking the other carb off cuz i already dismantled my 33 engine. is there anyway to find the size through a manual or threw another source???
Chinewalker
Not that I'm aware of...
boobie
You can compare the sizes of the two carb venturis by measuring with an inside caliper.
