Nos4r2
- Joined
- Dec 12, 2004
- 1,533
My Microplus 500 is rated up to 85hp, but she was built in 1976 before outboards were rated at the prop. She only has a 15" transom (see pic of an identical boat).
<br /> The maker went out of business in the 80's so I can't ask them this either, BUT...<br /><br />1)If I put a recent 85hp will she be overpowered or is this rating likely to be due to weight because of the short transom-in which case<br /><br />2) Can I put a 90hp merc 2stroke from around 88 on her as the 70hp and 90hp are all based on the same motor and should weigh the same.<br /><br />Common sense tells me not to do it, but there are always exceptions, depending on the variables the manufacturer used to arrive at the rating.<br />I'm bearing in mind that anything above 85hp in '76 was a darn sight heavier lump than it is today-the merc 90's were IL6's and the OMC's were V4's and physically a lot bigger and heavier than a 3cyl merc 90.<br /><br />This is only a thought as I'm broke at the moment but I'd like more power!<br /><br />Opinions here are valued. Cheers guys.
