HT383 crate engine?
E22
Looking to build a 383 stroker for a straight inboard application. I have a low-hour, vortec block that is a great candidate for rebuilding but then came across the HT383 crate engine from GM.
My goal is for a cruiser-type build, to maximize low-end torque and durability. It looks to have all the right specs - good cam, 9:1 compression ratio, etc. - but GM adds a "not intended for marine applications" note to the description. Outside of the freeze plugs and maybe the oil pan(?), are there any other obstacles to moving all my components over to this block? What am I missing?
E22
Here are the specs:
  • Horsepower​
    323 HP
  • Torque​
    444 LB-FT
  • Tech Specs​
    Engine Type: Chevy Small-Block V-8
    Displacement (cu. in.): 383
    Bore x Stroke (in.): 4.000 x 3.800
    Block (P/N 88962516): Cast-iron with four-bolt main caps
    Crankshaft (P/N 12489436): 4340 forged steel
    Connecting Rods (P/N 12497624): Heavy-duty PM steel
    Pistons (P/N 12499103): Hypereutectic aluminum
    Camshaft Type (P/N 14097395): Hydraulic roller
    Camshaft Lift (in.): .431 intake / .451 exhaust
    Camshaft Duration (@.050 in.): 196° intake / 206° exhaust
    Cylinder Heads (P/N 12558060): Vortec iron; 64-cc chambers
    Valve Size (in.): 1.940 intake / 1.500 exhaust
    Compression Ratio: 9.1:1
    Rocker Arms (P/N 10089648): Stamped steel
    Rocker Arm Ratio: 1.5:1
    Water Pump (P/N 88894341): Cast iron
    Recommended Fuel: 87 octane
    Ignition Timing: Base 10° BTDC, 32° Total
    Maximum Recommended rpm: 5000
    Balanced: External
Head gaskets, core plugs, water pump will need to be changed
You could go to a better cam, or switch to 1.6:1 rockers. The cam in there is a bit mild, even for a boat
Ayuh,..... Welcome Aboard,...... If I was gonna buy a nearly drop in crate motor,....
That one is My dream,....
If I was buildin' a 383 with my local machine shop,....
I'd build it quite abit differently,..... startin' with deck height, 'n piston shape,....
jimmbo
"...but GM adds a "not intended for marine applications" note to the description."
Perhaps that little Tidbit is Important... but it is your Money and Time...
E22
Yeah I guess I was looking to take a shortcut. Let me ask you guys this - back to stroking my current motor, are you aware of any off the shelf stroker kits that get me a 9.0+/- CR while keeping my 64cc vortex heads? everything I’m finding gets me to a 9.4 minimum which is too high I believe for 87 octane. The numbers say I need a piston dish of 28cc+ to get the CR down (with a reasonable quench) and I’m coming up empty on finding them.
Scott06
Stock marine 5.0 and 5.7 are 9.4:1 so dont see an issue with 87 and 9.4 CR
