Hub repair
doors67us
Hey guy's,I'm wondering if anyone has tried or has fixed a spin hub ? I'd like to try to repair mine off my 25 hp Johnson,if so what types of adhesive would one use,and the prep steps,I can get a new propeller for around 80$ but thought I'd give this a whirl
flyingscott
You have to have a replacement hub. Those are press fit once they spin they are junk.
doors67us
Nordin
No replacement hubs in the market for these old props I think.
I have not sean any.
Ebay or Craigslist would be a source for used props.
When I worked in an outboard shop 55 years ago there was rarely an issue with prop hubs slipping.-----Or a motor that could not be repaired.-----Reason for that ?-----There was no such thing as a motor that was more than 20 years old.!-----Today folks walk in with a 60 year old motor to find out that materials have failed.-----Going to be worse with the new motors of today.----Too much plastic / wires / electronics.
doors67us
Yes ,I totally agree with you on that, everything is made cheaply, plastic, Chinese garbage,the old OMC outboards where made quite well
tphoyt
You could try some 3m 5200 on that and keep it for a spare. I wouldn’t have any trust in it to get me home.
doors67us
Oh ok , I've since repaired the hub, pressed it back in and used gorilla glue epoxy, haven't tested it yet,the results are to be determined
doors67us
Yes ,old hub came out unscathed ,so I cleaned everything up well, put gorilla glue epoxy all over the hub surface, pressed it back into place
Scott06
the rubber in hub should be putting enough pressure on the prop to keep it in place, over time the rubber degrades loosing its press fit... it is not glued in
doors67us
Yes,I understand that,it's just an experiment,if it doesn't work I ain't out ,but like 5$ for the gorilla glue epoxy,I have another good prop on it now,gonna buy a new one soon
airshot
Curious to see the outcome, for a smaller motor it might work, would never trust it on a high powered motor.
