Hub slip question
will941s
If you draw a line across the hub of the prop to the barrel, when you run and not hit anything......should the line be broken? If this does happen, is it a indication of the prop needing to be repacked? If it is ok....how much slip would be normal? Cleaned off the carbon and noticed mine had changed.....moved about a inch. Not sure if it has gone full circle or not, but it's not lined up. Have not hit anything since I re-marked it.
Lawnmedic
Re: Hub slip question
If it ever moves you need to get it rehubbed. It may only slip a little now but one day in will let go when you need it the most...
captkevin
It isn't really worth getting them fixed. You can probably replace for the same amount as fixing
Texasmark
Buttt, yes you are onto the correct method of determining that you have a hub slippage problem.
Mark
mpsyamaha
i recently had a prop rehubbed for less than $70.... thats a lot less than a new stainless prop. and no it really should not slip at all.
