Hub with L68149 both Inner & Outter?
Snowfish
We need a new 5 bolt idler hub. Hub is beyond repair. It's a greaser, not oil bath.
Clincher is it has L68149 bearings both inner & outer. No problem finding the tapper spindle hubs with the L68149 on the inner. Drawing a blank on locating this hub.
Have searched the forum, Iboats store, E-Trailer, Rigid, Red Neck, Northern, and more.
Any other ideas? Thanks.
Snowfish
Re: Hub with L68149 both Inner & Outter?
Thank You So Much!
You ain't a kiddin' that's and odd duck. Thought I was in the twilight zone for a while.
Thanks again.
guy74
Certainly odd, took a little bit of searching online to find. While I was looking for it, I came across another odd bearing arangment, used 2 LM67048 bearings on a 1.25" spindle. I am blessed with 3/4 and 1 1/4 inch bearings on my trailer, this is an odd hub that is hard to get locally, I have considered making one of those spare tire mounts that uses an extra hub assembled with bearing to hold the spare. Maybe that is something you might consider.
