jserb
Thread starter- Joined
- Nov 29, 2005
- 406
Re: HUGE PROJECT!! 30' Scarab Sport overhual
So what your all looking at is all those little stress cracks in the hull have been V notched out and drilled out at the ends. To someone who dosent know the history of this boat, all these stress cracks may look like there is some serious structural issues with this mold, however knowing that when I bought the boat the guy before me had ripped it apart and let it sit in 2 pieces for about 2 years, then half hazzerdly put it back together just before I bought it, then I took it apart and flipped it and then squeezed them back together?.bla blab la bla, as you can see this shell has been push around quite a bit and needless to say im confident most of these cracks came from all this movement.
So I knotched them useing a grinder and then drilled the ends of them, then came back with ?easy glass? a bondo like material for boats, and now currently I am coming back with a ?glazing putty? to fill in all the high and low spots along with the fine scratches the previous sanding left behind.
Progress has been slow to say the least?.it was -15 here the last week and I wasn?t going to go heat up the garage and FIGHT the cold so I pretty much lost a week here. However what did go quite well was my Turkey Baster Trick. After putting the new wood core in the floor and flipping it and putting it back together, I noticed in 2 spot the darn floor delaminated. I coundt figure out why at first but then I remembered I used PL 5200 and resin to stick the two pieces of material together, and it was two areas where the 5200 actually created a small ?air? void and thus had a little ?flex? in the floor in these two areas. So I drilled a hole in the floor and took a turkey baster and filled it with resin and the void and set about 200 lbs of weights on it?.and boy its nice and solid now!
