I like the 30 second cleaner bought at home depot. Just spray it on, wait a couple min and rinse it off. has always worked good for me.
It's been awhile since I've been on. Not sure if this is in the right spot. I'm trying to clean the algae and stains off my fibreglass boat bottom. I bought the slimey grimey put on, pressure washed off most of thick algae, but there is still the water line stain and some other crud. I've read to try muriatic acid, (half and half),toilet bowl cleaner, and pool cleaner. Also bought this Clorox stuff last night tried it , but it didn't do much. Any thoughts?
muriatic acid?..man i would never had figured it would work for that.. I have used it to clean bricks after i lay some treads to clean up overspilled mortar but for a boat??..
Is that stuff safe for the fiberglass in or out??.. I have some mold from the pine trees around me and that is a B*&*TCh to clean..
muriatic acid.....while fantastic for lots of stuff is very harsh on boats, and will not remove hard water stains...
the pros use industrial strength toilet bowl cleaner
the toilet bowl cleaner is a watered down muriatiac acid with other chemicals in it that will remove the hard water stains.
the results are instant
as with all chemicals....wear safety equipment
any galvi trailer parts must be covered with poly.
