Hull Cleaning
firemedicjoe
We purchased a new (to us) boat last week. The hull is discolored because it has been docked for the past couple of years. Is there anyway to restore the nice white shine that is underneath all of that or is the only thing that will fix it is a coat of paint?
cjjjdeck
Re: Hull Cleaning
Usually the discoloration is from algae. The way hulls are cleaned in our area is spraying a muriatic acid solution on the hull, then, following it up with a pressure washer before the solution dries (avoid decals, use a vinyl cleaner on them. Also be careful with the pressure washer around decals, avoid them or hit them at 90 ? angles only!). If applied within say a year or so, hulls come out looking like new most of the time. You can do it yourself, or most marinas offer this service, usually at not to crazy prices (of course, now having said that??..).
The discoloration may be harder to get off completely if the boat has been out of the water for more than a year. Not cleaning the hull for more than a year or two gives the algae a better chance to permeate the gel coat and set in, especially when it?s not in the water. If too much time has gone by it makes it almost impossible to get it completely out. When the boat is in the water the algae tends to stays more on top of the gel cote. Cleaning the boat right after pulling it out to prep it to store for the winter, or when you pull it out of storage and prep it for the new season, gives the best success rate. Waxing the hull to prevent this condition makes the discoloration problem worse (although you would probably think the opposite, I did, also this pertains only to fiberglass, not ). For some reason, wax helps to provide an easier way for algae to permeate the gel cote.
So, the longer that discoloration has been on the hull and out of the water (and hopefully the hull wasn?t waxed), the harder it will be to restore it to like new condition. The only way to find out is to go through the cleaning process.
moosehead
Re: Hull Cleaning
^Great info thanks cj.
I've had great luck with Starbright's hull cleaner. We wet slip during summer, and typically clean the hull with this stuff once mid season, and again prior to winter storage. Good idea to use gloves, mask, glasses.
Instant Hull Cleaner
seilings
Re: Hull Cleaning
I just tried with the toilet bow cleaner, spay it to the hull, and wait 5 minutes and reins it off. Works just great.
southkogs
Re: Hull Cleaning
... and don't underestimate the power of a Magic Eraser. ;)
moosehead
Re: Hull Cleaning
Out of curiosity, a MSDS review of some mildly acidic cleaners popular for hulls showed the following:
Starbrite: 5-10% Oxalic Acid
Bar Keeper's Friend: 5-10% Oxalic Acid
Sno Bowl: 10-20% Hydrochloric Acid
Mary Kate On Off Hull Cleaner: 20-25% Hydrochloric + 5-10% Phosphoric, 1-5% Oxalic
Not sure what kinda punch is in magic eraser, but it's good.
BRICH1260
Re: Hull Cleaning
The generic "Hull Cleaner" that Walmart sells always works for me, runs about $8.00/ bottle.
dazk14
Ensign
Re: Hull Cleaning
On and off Mary Kate is what most pros use. Nasty stuff- but works.
