hull extension in progress with pics
Status
Not open for further replies.
oops!
Re: hull extension in progress with picks
the boat turned perfectly......the hull was dead straight on the water....it really was a joy to drive.......
as you can see here....we are still running rich in the fuel....and the boat has a slight list to starboard....thats because of the seat and the battery (i only used one for the test instead of the opposite side two batterys.
the seats i am using here are form a chrysler lebaron.....they feel great you sit high and very comfortable.......the bases are swivel. the seats will be recovered in the theme colors.
now.....
the fault report !
as stated, the boat is heavy.....the boat was weighed around 4100 with the trailer....the trailer is about 800 lbs. so after completion.....it should weigh about 35-3700 lbs wet.
the carb was acting up bad...somthing that didnt happen the other day.....at 2000 rpm it crapped out till 3000....so a lot of acceleration tests were not completed. it is still burning very rich...
bad leak from the drain plug.....i have no idea how this happened ! it was put in well with a lot of sealant.....but it is a minor fix.
minor leak from the trim pump....after we turned the boat off...we heard a leak....but the drive stays up.
there was a bad vibration at around 3k it seemed to level out around 4000 rpm but still...i have no idea where this came from.......when you rev the motor on land....it is fine.....but i would consider the vibration to be severe....it is possible that the drive has a bent prop shaft. however we are going to try several different ways and investigate this to find the cause....it could be just a bad prop.
the prop......i chose a 19 for the test because it is a good intermeadate prop. however at 4200 rpm the boat was gps ed at 67 kph....about 45 and i had a third throttle left to go.....so i need a bigger wheel...possibly as much as a 25 4 blade. however at 4k and tou accelaterated to 4200 the boat really picked up...in fact...it beat the bayliner in a race.
minor gauge problems...all in all the problems were all mechanical.....the hull it self....besides being heavy......was perfect.
the good stuff..........
i love the way the boat handles...it feels so strong....solid. it turns like its on rails.
i love the way the chairs feel and how high you sit.....i literally didnt want to get out of the boat.
the windows were great.....it really cut out the wind coming down the sides.
with a different prop and the carb tuned...it is possible that i hit the 60 mph mark.
the heater !......
this was a really pleasant surprise....it really changed the boating experince for me....even in the hotter days....it can be cool in canada in the evenings if you are wet or damp from swimming or skiing....
the heater just took the edge off.....
i highly reccomend that any one that is building a boat add one. im my opinion now....it is a manditory item.
all in all even tho it needs more testing ..... at this point im calling the hull extension a sucess....it could be lighter....but dont forget...i had never done major fiberglass work before. and i wanted the boat strong....strong was the trade off against weight.
noklu and i are going to rip into it tommorow and possibly do more water tryals if i can get the mechanic to fix the carb...(he rebuilt it) then we will be looking for that vibration.
cheers
oops
mrdjflores
looking great bud!!!!!!!!!!!!!!
ezmobee
60MPH? That's awesome! Boat looks great. You really nailed the windshield wings. Such a cool boat. Glad things (for the most part) went well.
boatsarefun1
Banned
That is really great! Sorry to hear about so many problems, especially the weight issue (and I see you still have not added the seats and other materials like wells, wings and such that you spoke of in earlier posts. That will add an extra 400 lbs or so making the boat heavier and less fuel efficient and handle poorer). With all that extra space, and you fill it up with people, how low do you think it will sit in the water? What impact will it have on handling? What is the new center of gravity?
After reading this thread, its an admirable project, but I think the lesson to be learned is this:
If you want a bigger boat, just go buy one and be done with it.
fixb52s
It has been awhile since I posted here, but have been following it the entire time. Ward, first off I want to say great job! Getting it in the water is a huge step. Now all the small stuff remains, but I know as you do that it will take some more time. Having it run straight under power makes all that work worth it.
mike64
That was exciting to finally read about the water trial! All things considered, sounds like it went about as well as you could expect for a first time. And about the weight, it doesn't look like it sits too awfully low in the water, and it sounds like it will be plenty fast. The window wings are perfect for the boat-- it looks great.
redfury
No project goes without hitting little snags, yours has been no different. I'm sure the euphoria trip you just got is more than enough motivation to keep at it strong.
The side windows do make that boat look proportional now...any wakeboard tower will just add to it ( one of the reasons I put the tower out back when I mocked it up was to try to adjust for visual proportions ).
I think I speak for everyone here when I say that I can't wait to see it in action ;):D
boatsarefun1
Banned
I think the last thing he needs now is more weight. By his own admission, the boat is overweight. Lets suggest ways to reduce, rather than add to the weight of the project. And remember, he hasn't even added the interior yet!
tinkeringwackyone
looks great oops! glad that the initial test went well. so happy for you.
osborn159
wow, that must have felt great to have her on the water 1st time since all your work, i still have not read the whole thread, but do come here for any
???s i have 1st, so you not only have a great "new" boat, you also get the pleasure of helping those that may not have as much experience as you, and for that let me say thank you.
hope she provides you w/ many years of trouble free boating. D
izoomie
Looks great, and even I feel better after reading this entire thread and seeing it in the water.
ezwitter
glad to see you tested it. keep plugging alone (good luck)
erikgreen
Big, big congratulations Ward.
You've stuck with this thing through a lot of issues in life that would make anyone else have quit working, and attempted a lot of repairs and modifications that would make professional boat workers shake their heads and sneer. You've done things that make us proud to know you here at iBoats.
I hope it feels every bit as good to get on the water with that thing as it should, and I'm looking forward to seeing you finish the "fun stuff"... the interior, seats, etc. Putting icing on the cake is always a great time.
I'm jealous of your speed... same weight (a little less, actually) and same engine in my boat and I barely make 45 with a 19 pitch. I think I need a new carb.
Post the specs and source for your heater, I want one :)
Erik
scipper77
Erik
I would guess that you have a wider beam unless you also did a hull extension. I guess I'm just saying that your hull might be a bigger factor than the carb for top speed.
jcsercsa
MAn she does look great with the windshield on there !!!! and the best pic was the one with the wake behind you !!! looks great buddie !! John
ddrieck
oops,
Happy to see all the hard work and determination is finally paying off for you!!!
The stretched limo looks awesome with the new side windows and I can't wait to see how she looks with the wake board tower, if that's still the plan.
Huron Angler
Great work oops, glad to see her finally getting wet:)
It's nice to see someone defy the odds and believe in themselves.
Can't wait to see some vids!
Andy in NY
Oops, i've been following since day 1 and have been looking forward to this for a while now. You did a killer job! big ups to you and everyone who has had their hands in it so far, and I REALLY can't wait to see the final product!
coastalcruiser
oops!
Nice!!
been following this post all the way.
Congratulations! love the way she turned out, cheers to you and all the people that helped.
NoKlu
One thing we forgot to mention is the Bayliner quit just as we were done for the day,so we have that to fix as well. Not to sure we can do much about the final weight except not to allow any fat chicks aboard. :D
Status
