oops!
- Joined
- Oct 18, 2007
- 12,932
Re: hull extension in progress with picks
i have nooooo idea why my phone didnt ring.........space junk i guess...!!!!
well stupid me....
....ran into a snag....again....
the first thing i had to do when o got there was to set the frames in place and check for any new glass that may have gotten in the way from the bulkheads being glassed in
there were a few small problematic areas ....but no biggie.....so i added the rest of the frames and got them ready to glass in to place.
all the areas were re acietoned.....i applied a layer of really thick csm ondarvr had given me......i dont think ive seen csm that thick....im guessing 2 oz's....mabe 3....you cant see thru this stuff and it is really thick in your hand.....but did it ever work great !
i applied 2 layers to each frame hull joint....
the csm didnt even drink too much...and it was cooler in the room tonight as the temp is dropping here.
with the frames curing.... i turned my attention to the motor mounts......
the mounts im using are manufactured beams...cut to spec......ive had then drying for a long time....(usless because they were allready dry....but the dryer the better).....the other day i had wrapped them in csm and prepped them to be installed.....
what i forgot is.....that i had never ever test fitted them...ever !...i knew my measurements were correct.....finally the other day i cut them to legnth....the beams needed to fit the transom shape...so i cut them at that angle ....but never test fitted them.......one fit like a charm....and one sat an inch too high,,,,that was beacause of some glass in the hull at the stringer joint.......that ment i had to grind away some of the corners of the mount to get it to fit properly.......
THAT MEANS.....i have to re apply some resin....that means i have to wait to cure....that means it cant go in tonight !....
well stupid me....
