hull extension in progress with pics
Status
Not open for further replies.
Renny_D
Re: hull extension in progress with picks
The only way to turbo a marine motor is to have it custom built... as far as I know there are no stock turbocharged marine motors. Mostly this is because a turbocharger works off of the engine's exhaust pressure... in cars the exhaust is used to turn an impeller that drives more fuel/air mix into the engine.
This is fine for cars, but on a boat it's more complicated because you usually have wet exhaust, so you have to run the exhaust through the turbo then out through whatever the rest of your exhaust system is, EG wet manifolds or through-hulls (with mufflers if you're anywhere that needs them). The simplest system would be to assume a dry exhaust like a through-hull system. But then you have to have a "special" turbo... the turbocharger is powered off of engine exhaust, so it gets really hot. Not a huge problem for cars since it's under the hood, but in a boat the temp is a fire hazard, and it exceeds the coast guard's temp limits for inboard boat engine parts. So a turbocharged boat won't be USCG certified, and may be hard to insure, unless it's listed as a race boat, which is another can of worms.
I've been looking and you're right it will have to be a custom installation unless you were going turbo diesel which there are many of available. You're also right that there is a fair bit of heat but heat wraps would take care of that no problem. As far as water in the exhaust it doesn't come out of the head that way it is added at the mixing elbow so adding a turbo would require that the turbo be plumbed into the exhaust prior to adding water to it.
Well, your point of view is similar to a lot of car type folks I've seen that are new to the boat world. It's apples and oranges though.. here's why:
A turbocharger can be designed to provide a low end boost to a point, but it's only a fraction of its rating, IE 1% addl HP or so. Look at a dyno graph of a turbocharged engine vs an identical non turbo engine and note where the power is mostly provided... power increases exponentially as RPM increases, because the engine is providing more pressure (in the exhaust) to turn the turbo. This is limited by materials, exhaust pressure, and the max turbo RPM of course.
Turbos run off of exhaust gas, and at low RPM there just isn't enough exhaust pressure to provide a noticeable boost.. in a turbo powered car there's usually an engine RPM where the "turbo boost" kicks in. If you're not ready for it in some cars it may even cause a safety issue since you suddenly get a kick in the pants.
In a car, you use a transmission to absorb your engine's power and transfer it to the wheels at a useful RPM.. for instance redlining the engine at 9000 RPM in top gear you're usually converting the 9000 down to 1300 or so, since you can't really turn the tires at 9000 RPM... part of that conversion is in the transmission, part of it is in the differential. So gaining power by increasing RPM is useful... you can live with lower torque if your RPM increases because your transmission can convert the RPM into torque at high RPM, and you can downshift to get moving quickly at low RPM.
Additionally, tires can run efficiently at a large range of speeds... unless they're slicks, or running in wet/icy conditions, pretty much one rev of the tires moves the car one tire circumference.
On a boat, it's really a different system. I'll use an I/O as an example since that's what I know best.
The engine runs at its factory RPM usually.... for a chevy small block that means WOT is about 4200-4600. It doesn't make much sense to go higher for several reasons related to power (see below) but another major reason is the usage graph... if you graph a car's engine RPM over time, the graph will show spikes as you shift, speed up, etc. A boat's engine typically is revved to a certain RPM and left there... for hours at a time. Imagine how long your hopped up car engine would last if you got in the car, started the engine, left your driveway, then floored it and held it down for 6 hours? Boat engines do that all the time.
The engine output runs into a sterndrive via a rotary coupler. The sterndrive is basically a pair of right angle gear transitions that move the rotating output power down about three feet and reduce RPM by between 2:1 and 1:1 or so. Only one gear ratio is available, although you can shift forward/reverse and neutral. It's not built with more gears for reasons related to the prop (below), but another reason is the use curve again. In the above example driving your car, which component would die first, your transmission running redline all the time or your engine?
So the power goes engine->sterndrive->prop. Here's the real difference between boats and cars (like you didn't know, right?). The prop isn't friction based, it's a reaction drive. The blades shove water backward, and the boat goes forward.
Due to the physics of propellers (they're simple machines, basically archimedes' screw) they have exactly ONE speed and a small range of RPMs they work most efficiently at. Speeds (defined as forward movement through static, non churned water) below that limit they still work, but rather poorly. Speeds above that they still work, but deliver no extra thrust no matter how much faster they turn. RPMs below that range still work, just poorly, and RPMs above that range don't work at all (see below).
The no extra thrust at high forward speed is a limit imposed by the prop pitch.. basically the prop (and boat) are moving through the water too fast for the angle of the prop blade to get "ahead" of the water flow and push backward... if the prop isn't able to shove water backward faster than the flow around it, it's effectively standing still (think about it). Increasing the angle the blades grab water ahead of them at increases the prop's pitch.
Why the RPM limit? Water isn't solid. It cavitates, IE transitions to vapor under enough pressure. Also, a boat floats on the water's surface, so the prop is always near the surface. Boats can push air under themselves and into the prop sometimes, or the trim mechanism can move the prop out of the water. If the prop is not designed to pierce the surface (some are in fancy Arneson drives) then this is called "ventilation"... it means there's bubbles of vapor or air around the prop that are affecting thrust. The prop on a boat doesn't push air very well, and it provides not much push with bubbles. Higher RPMs have the potential to create more bubbles faster, up to the point where you're pushing almost no water, just creating bubbles.
So in addition to one forward speed where any given prop works best, there is pretty much a small RPM window where it works at all. Below that window its thrust backwards doesn't exceed the turbulence created by the blades (imagine a prop turning in neutral) and above that RPM it starts to ventilate and thrust drops.
So then... the gears in the sterndrive lower the engine RPM at WOT from 4200 or so down to (in my V8) about 2800 RPM maximum or so. That's a good range for my 14.5" prop to spin at... not too much ventilation. I can still adjust prop pitch by replacing props, which changes how much water gets shoved backward with each prop rotation, and sets my max speed. I can't go above a certain pitch limit though, because the engine has to have enough torque to overcome the resistance of the water to the pitch I choose. Resistance goes up as pitch goes up (to go faster you need a higher pitch prop, to use a higher pitch prop you need more TORQUE!).
Now there are a couple other things to consider here. First, boats need a good amount of thrust at low RPM to get on plane... this is another difference between cars and boats. Cars have a linear required power curve from 0 to wherever drag starts to have a significant effect. You can speed up to 20 or whatever, more with the wind, using a certain amount of torque (once inertia is overcome) to get moving, then add RPM to go faster. Hence the multiple gears in a car transmission.
A planing boat must first push itself OUT of the water, so most of its hull is in air, in order to go faster than a "displacement" hull whose speed is governed simply by its length. A displacement hull does not go faster than its design length period, no matter how much power you add. So to go fast we need to get our hull out of the water. This reduces friction from the hull and we speed up.
That takes a lot of thrust.
So we throw power at it... we go WOT to turn the prop at the top end of the RPM it'll make power at (remember it works better and better until it reaches optimum RPM and forward speed) and hold at WOT until we're on plane, at which point the decreasing drag and increasing forward speed causes us to speed up a LOT (faster speed means the prop works better, which means more thrust, which means faster speed...), and we cut throttle back to hold the speed we want on plane.
We could just use a lower pitched prop, that works better at low forward speed, to get on plane quicker, right? But you need a high pitch prop to go fast! So it's a trade off... high top speed vs. good "hole shot" or getting on plane in the first place.
With me so far? Take a break, get some coffee, I'm not done yet :)
So what happens when we add a turbocharger? Well, it adds HP (which is a measure of work done over time) by adding RPM, which is part of the HP equation (it's actually HP=(torque(lb/ft)*RPM)/5252). If you look at the equation, it makes sense that you can increase HP by increasing RPM (how fast the motor spins) or by increasing torque (how hard it tries to spin).
So engine ratings in HP are deceptive... two engines with equal HP may have wildly different torque ratings.
Setting aside the engineering problem of installing one and keeping it cool in a boat, a turbocharger adds power by adding RPM. Which it does very well above a certain minimum RPM level.
Hi Erik at this point I would return your quip of earlier - these is the kinds of statements that people new to turbo charges and turbo charger theory make. Turbos run off of exhaust pressure ratio not rpm. A belt driven centrifigal supercharger is a lot more like what you describe. Anyone who has ever driven a turbo anything knows that without a load a turbo will produce no boost. I can sit in neutral and floored till I'm bouncing off the rev limiter and I'll have less than zero pounds of boost - this thing called vacuum. Why is that what's happening? With less load it takes less fuel and oxygen to push the piston down turn the crank etc. Place a load on it and more air and fuel are required to push that piston down. So turbos are load based not rpm based. Turbos add torque not horse power exactly what you want in a boat motor. If you look at dyno graphs and I've seen a lot of them turbos add Torque in the mid range and often in low to mid range. A properly sized turbo added to a na motor will have a flatter torque curve than what the engine had before it had the turbo but in general it will still follow the torque curve of the engine. The torque curve on piston motors is driven primarily by the cam. Also to the question of efficiency you mentioned earlier - again it comes back to sizing of both halves of the turbo. You size the turbine section for the approx spool time you want then the compressor section for the amount of airflow you need. With a properly sized turbo you will be at the begining of your efficiency island trying to come out of the hole and at the other side of the island at your fast cruise rpm that means you'd be a 90% of the efficiency the turbo can provide in the range that your boat operates 90% of the time. How does this happen. At the lower rpm setting the there is a big load on the engine therefore a lot of available exhaust gas to turn the turbine - remember the turbine was sized to the spool range we wanted - the turbo spools up to the boost setting it was set at and the waste gate opens dumping excess exhaust gas. Now the turbo stays at that boost setting (pressure in the intake manifold constant) and the cfm ingested rises as the rpms go up.. As the boat comes out of the hole the load lessens - less exhaust energy - and the wastegate closes some and as the load continues to drop the wastegate will be fully closed. Then depending on hull shape the boost may actually begin to come down. In a sense the turbo will begin doing what the driver will eventually do with the throttle. This is exactly what we are looking for. I'm in the process of trying to contact the company that built that turbo v8 boat as I expect that you are very wrong about how the boat operates - my guess would be if there is anything bad about how those boats come out of the hole. I would suspect it has nothing to do with the turbos and everything to do with prop selection.
I'll see what I have in my notes... unfortunately prop design is a very black art as far as the internet is concerned. It's an older field though, so you can find books on the subject here and there... the problem is that they're written for naval architects and aeronautical engineers, so you have to have a heavy math background to keep up. I really don't. A couple more things that may come up with regards to turbos, I just think I'll throw them out here for thought. First, I know there are a ton of turbos out there of many sizes, drive types, shapes, etc. with different lag/boost threshold. Even though you can get models that, like a supercharger, provide forced induction across the whole RPM range, they still don't add much, if any, torque.
That is all that turbos add - plain physics makes that so. It's turbo selection that decides where that is applied
Show me a turbo that provides an additional 10% torque or more and can still let the engine use 87 octane gas without additives and I'll be interested :)
If you insist I'll try and find documentation of that for you - I did some quick searches and just finding prop dyno sheets are a pain. The issue about fuel octane is all about ignition timing and retard and advance curves. That's like saying you can't run a high compression engine on regular - you can you just back off timing - are you getting the most out of your engine no - will it run fine and be happy there sure. I also know first hand that this is true. My car in na form has 92 hp and 105 ft lbs of torque, on 87 pump gas limiting boost to 12lbs I make 168 hp and 218 ft/lbs torque. Now run e85 or race gas and I'm now making 330 hp and 390 ft lbs torque. So it's not will my engine run on 87 but more of why would I. I know for the most part we eschew electronics on boats for reasons of corrosion etc but a knock sensor based timing retard will give you the max torque available for any fuel used - they even use those on high compression engines.
More coming - I had it all written out in one response but we're limited to 20k words. I didn't want to delete any of what Erik was saying both for fear of hearing my response was made out of context and out of respect for the time Erik took to respond. So call this part 1 ;)
Renny_D
Re: hull extension in progress with picks turbo discussion part 2
Ok part 2:
Turbo diesels are great... no argument here. They're not gas engines though, so saying a gas turbo is good in a boat because turbo diesels are good is like saying a flats boat gets on plane easily so it'd be perfect for pulling waterskiiers... you're missing the point.
Perhaps you were missing my point - which was to say that turbos operate very happily at low engine rpms and turbo diesels were prime examples of that. There are new turbos that have just come out that have variable turbine housings and they can make full boost at idle. I love watching this video - the controller they use is electronic but they have already been adapted to use a standard mechanical waste gate actuator so now we have an even wider operating range for a turbo infact depending on engine size/cam/compression combo most likely wider than the engine rpm range.
There are other ways than gear reduction prop drives to push a boat, if anyone thought of that. If you use something other than a gear drive, you can transform a turbo engine's RPM into useable power. But, all of the mechanisms I know about are less efficient at using engine power than a prop. So for a given engine size, even with a turbo, you get less thrust than just using the same engine with a direct gear drive and a prop. Three examples of non geartrain drives that come to mind are: * Waterjet drives * Hydraulic drives * Hybrid gas/electric drives like electric azipods Erik PS: Re: Avatar... thanks. I like that comic, and Belkar appeals to me. I can't wait for the next panel monday... looks like he's going to open a can of whoop a**...
They're operating, sure.. but with what prop and drive unit? What are the turbos adding over and above what those engines could produce without them? I'm pretty sure with that first hull, assuming it's light enough, an EFI 9.4 liter chevy engine like they use (gen 6 or so) could come close to those numbers with the right prop, without the turbo. With the same prop that's giving the first boat the 114mph pass, what's the hole shot like? And if you know, what's the prop slip at 114? You CAN put turbos on a boat engine and have them spin, just like you can attach NOS injectors, or a special magnet that "aligns" the fuel molecules, or a set of pasties with tassels. The question is, whether it improves performance, and for how long. A half pound of C4 detonated off your transom will give AMAZING performance... for a quarter second or so. I think a lot of the companies and private users out there who add these turbos to boats either don't know much about boat drives or don't care. Notice how all the videos they post are short "speed runs" where they list the max MPH? It's almost like guys who are drag strip wizards with hot rod engines decided to buy a boat one summer and see how fast it'd do the quarter mile :) I've yet to see any boat engine with an added turbo that performs better than the same boat without the turbo, or more to the point performs better than just spending the money on a larger engine in the first place. I eagerly hope someone can come up with solid dyno torque numbers (measured at the prop) along with a prop that can use the torque, to prove me wrong.
I think turbos in marine gas marine applications are still in their infancy similar to electronic ignitions and variable valve timing are in marine applications - they are there but in small numbers. Have you seen a turbo on a boat period? As I said earlier turbos make torque - sizing the turbo puts that torque where you need it just like caming an engine puts the torque where you need it. That video showed a top speed run because it's an advertisement - what do you think would sell more custom turbo apps a video of a good hole shot or one of a 114 mph run on a 30ft v bottomed boat. What I would guess is that the boat is not producing the amount of hp/torque it could produce primarily for reliability and longevity
Come to think of it though, I may be making assumptions... Oops hasn't really said whether his planned use of the boat is quarter mile runs at high speed past the ladies followed by a leisurely putt around the lake for the rest of the afternoon to use the rest of his gas. If that's the case, maybe we DO need to put in an NOS system and turbo ;) Erik
I think the real question comes down to complexity versus simplicity and maybe a very cautious attitude (politically correct wording) about technology and innovation in the marine industry in general. Would a turbo work in a marine application - yes. Could it be reliable yes. Would you have more torque/hp and a wider operating range - yes. Will it be more complex - yes. Will in require more fabrication and creativity to pull it off - yes. would it be a fascinating project and have a hell of a look at what I have in here factor you bet you :) I seriously doubt that oops is going to run a turbo, not that he doesn't have the ability to be a vanguard as we all surely know he is Capt. Kirk like (boldly going where no one has gone before and all) but because of the time and or expense and or complexity keeping the boat out of the water longer. However it was worth talking about and understanding as maybe there are others that would be willing to try. We could go further and just dump the reciprocating beast all together.. like this or evening crazier this
I admit that I am a bit of a turbo head having made the conversion from BBC to small turbo 4 cylinders. I like the intellectual challenge and the surprised looks in peoples eyes and I'm willing to deal with a little less reliability because I can't afford it right now - the old adage fast, cheap or reliable pick any two If I had more expendable funds you bet I'd go this route in a heart beat. Thanks for taking the time to let me rant a bit on this latest passion. Not quite the whoop *** that Erik predicted just me stating my opinions and passing on what I know of the technology. Sometimes I wish I was more eloquent and could be a better teacher on this subject but hopefully I got my points across. No matter what engine ends up in this boat it will still be an awesome boat and one of the best project threads I've ever read.
Thanks Renny
erikgreen
Renny -
Thanks for taking the time to type up a reply. I'm actually not going to go into it point by point right now, I may do so if I have some spare time upcoming at work or something. I enjoy this sort of thing, a little too much :)
There's something I'd like to publically concede... re-reading my statements above, I don't know what I was thinking when I typed the part about turbos and superchargers not providing torque. Of course, they do... really I must be getting old. They provide forced induction, which means you shove air and fuel into an engine at more than ambient pressure, which means you get more oomph in the form of torque and rpm (and therefore HP) out of the displacement you have than you would with less air/fuel. The important thing to remember is that in a boat, you can't do anything with that extra torque and rpm unless you change the prop.
But, if you do change the prop to use that extra power, odds are good you'll have a lot of problems when the turbo isn't providing boost. Like at idle, when you're trying to dock. You still have to spin the prop, right? But unless the turbo cuts in you don't have the torque to do it. If you don't change the prop and you use one small enough that you can run it without the turbo, then you get no advantage from the turbo anyway. The RPM does you no good either, without a prop that can use it, and if you put on a high RPM prop you'll have trouble with hole shot.
Superchargers are used on boats, especially on non prop drive boats and race boats with high speed props on them. No problems using the high rpms for something in those cases, and superchargers are always boosting, so there's no problem with lag. So why do you think neither Mercruiser or Volvo sells a supercharger equipped engine stock? ;)
Turbos aren't used in boats except in experiments because they are powered by exhaust pressure. Their power boost is triggered by (and adjustable by) engine needs (vacuum) via the waste gate, but still, exhaust gas is what spins the turbo. No exhaust pressure, no turbo boost. At idle, any boat engine I've seen won't run any turbo I've seen. Electric assist can help, but if you use it all the time it quickly becomes an electric supercharger, which sucks power like nobody's business. And boats idle a lot. I suppose you could carry a kicker motor just for idling around, and switch to your main drive for high speed runs :)
So if there's a turbo that runs off something besides exhaust pressure, doesn't suck 1/3 of the engine power like a supercharger, and provides boost across all RPMs, I'd love to see it. But I think I'd still buy a big block, or even better a diesel, for reliability.
For now we'll just have to agree to disagree I think.
Like you say, Oops probably won't go for an exotic engine, but who knows?
Erik
PS: My comments on the stroker still hold... it's better than a stock small block, but still less power than a big block :) Hey Oops, how about a Mercruiser 502 EFI?
erikgreen
One more thing Renny... yep, turbines are the big deal in offshore racers right now. There was a boat that crashed in 2006 that had two or three huge ones, can't remember which. It turned and went sideways into another boat, I think 4 people got dead. There were some pics of it earlier in this thread.
Let's redirect our conversation... if we assume Oops wants to maximize torque and RPM, minimize size (narrow 25 foot hull) and keep fuel consumption (and therefore displacement) down... what does that leave him with for options?
The stroker looks a bit better then... or maybe do we go exotic? Like a Mazda turbine?
proshadetree
Well now if that isnt enough info I dont know what is.Gives food for thought.I dont know what kind of power is going in there but if a man cut a boat into and adds 6 feet to it,I wont bet on anything.
colobiker
Renny and Eric.. this has been a most excellent conversation.
both of you are knowledgable individuals. it looks like the only way to settle this debate is for me to turbo my boat and see what happens.:D
thanks to the both of you for sharing your talents and thoughts. guys like you is what makes this forum what it is ...
a million thanks
erikgreen
a million thanks
I'm all for it! Let's get some actual data in here, numbers on your boat before and after!
I'll even buy the beer when you're doing test runs! :)
Erik
new_boater
NEED MORE BOAT PICS HAVING WITHDRAWALS :(:(:p
Renny_D
a million thanks
I can't wait to see what you come up with. Hit me up with any questions you have. I am foreseeing some interesting numbers out of that boat. I guess it would be good to know current top speed, time to get on plane, max rpm you have now and what prop you are turning.
An improvement in any of those would be interesting - I would guess an improvement in all of those and by improvement in prop either a bigger prop or a higher pitch or both.
On the engine thing... My thoughts for what they are worth. You can do all sorts of things to the average engine to get a huge jump in both torque and HP (They are the same thing.) but the problem is reliability and longevity.
If you look at what the OEMs produce you see that when they want more power they go to more cubic inches. Even then they keep the HP numbers fairly low compared to other non-boating uses. A big block Chevy at 330 HP is not a lot for that engine and it *could* easily crank out another 100 HP. Why don't they do it? Reliability and longevity.
Even with relatively low HP numbers the average marine engine is a short lived engine compared to non-boating uses. A 350 chevy in a pick up is just about broken in with 500 hours on it, in a marine application it may well be ready for a rebuild if the owner has driven it hard.
I think people often fail to undersand just how hard these engines work.
I wonder if this has more to do with their quality control. The volvo marine engines actually have a higher output than their automotive counterparts and I'm talking about the actual volvo engines not the rebadged Gm motors. They are actually sought after engines in Volvo hotrodding circles ( I know sounds oxymoronic :redface: ) because of their additional output. I also think there are improvements to be had here as well. I'm thinking things like additional oil filters, oil coolers. More frequent changes of filters. More regular running of the engines to keep condensation at a minimum. But you are probably right that a less stressed engine will live longer. For me it would be a question of would it be worth the weight and fuel mileage penalty.
Erik
I call shotgun :)
Renny
jcsercsa
Hay Buddie , man isn't this great , love the conversation on the engines !!
I know we talked about this before , how the truck series, aren't they running 4.3 in them and aren't they getting something like 800HP out of them ??
Well my vote is for a big block 400 , of how about the 6.2lt
and the supercharger!! you should get 600hp out of her and still be Petty reliable!!!!
I love the 383 stroker , but if your needing more tork them that can give ? what some 500lbs ?
the Desiel would be great , but for the price ????? and desiel price on fuel is still outrageous !!!
Ok now how goes the hunt for a new garage ??? John
oops!
im sitting back......watching and learning from an utterly fantastic discussion. im in awe of what has been discussed on these posts.
bubba just gave me some super deals to check out...
as far as the shop....im still in the hunt....there are some serious things happening at my store that require my attention so my shop looking time is only part time.......the appointment for sunday was missed on the most likely candate for a shop......(it was grey cup sunday in canada....the equivelant of the states super bowl)....so im not suprized the owner was not avalable....
but ill see it soon.......actually its allmost a done deal...as im goin halfers with two boat mechanics.
we just gotta see how the shop is divied up between us and weither its workable, as it is not a squair room.
i gotta admit....im chomping at the bit to get on this and get it done......i know if i was working on it....in the down time i have had in the last month....it would almost be finished to the point of building the interior.
the bench seats will only take a week each....and there is three......(actually i think i can make them all in one week....but im calling it a week each.
then fab the dash.......(that will be fun).....make the water slide and fab the swim grid.....
i have decided to re gellcoat the top deck....(cap)......after i get done extending the windsheild......drilling all the holes and preping it for the new toys.......it will look like swiss cheese any how....so i may as well re gell it and be done.......im not worried about re doing it....and i know it wont take nearly as long as the hull....i think that whole project will take less than one month start to finish .
ne7800
man i sware i have heard somthing like this before :D
oops!
im not sure exactally how far spokane is....but its REAL close.....when we went to vegas we broke down and spent the night in spokane.....i dont think its more than 5 hours......(that is real close for me....5 hours is a snap)
and thats a screaming deal.....a b/'n turbo diesel??? my bravo 3 is made for that thing !
jcsercsa
There yea go !!! NOW I GET SHOT GUN !!! hahahaha
yep I think thats a heck of a deal !!! I dont know how much it would even have them ship it to you !! crossing the boarder and all !!
but there you go you wouldn't need a new drive !!! and you would have tork out your ***** !! lol
Man with that thing you could pull all the Canadian Navy behind you !!! hahahahhaahahahahah John
oops!
sooo not to throw a wrench into any fantastic discussion we are having.....but what about diesel?
the gear ratio on my b3 is 2:44. so how are they getting the spin speed to the prop of a deisel powered craft?
wouldnt they have to overdrive a drive to get the spin speed to the prop?
douglee25
The smaller diesels are typically higher reving than the larger diesels. Combine that with prop pitch and you will have boats that reach speeds from high 30's to low 40's with a diesel.
Doug
erikgreen
Yeah... basically you need to look at the torque and RPM figures on the engine you're using and match that to drive gearing. If the diesel's WOT RPM is 4000 or so then you could go with V8 gearing (1.5:1).. I think the big blocks use 1:1 or similar.. you need to spin the prop in the right RPM range for the higher end B3 prop sets... Mercruiser could tell you the range.
Almost any diesel will have the torque you need without a geardown, including that one, so no worries on that. Just get the biggest (diameter) prop set you can for the B3, then choose the biggest pitch with an RPM the diesel can do :)
I'd ask the seller about marine uses though.. it looks like that's the price for a base block, probably it's more for a marine unit.
Diesels are great for boats, period. They like running at a constant speed forever, have plenty of torque, lots of energy per gallon so you get a long range, they tend to last forever, etc.
They also tend to be heavier than an equivalent displacement gas engine,so be aware of that. You'll also need a diesel certified fuel tank.
Erik
oops!
what is a marine deisel?.....any one know...????
is the cam different?
dist....nope. alt...yes. starter...yes. but out side of the bolt ons....????
Status
