hull id other than rear of boat
spazzer
Is there a hidden hull id that the manufactures put in other than the one on starboard rear of boat? Boat has had transom repaire work done and the id tag screwed back onto transom. This is on a 1995 nitro. Thought that year should of had id embedded on right rear corner below rub rail but doesn't. Just want to make sure everything is legit about this boat. Thanks for any help.
Cadzilla88
Re: hull id other than rear of boat
my tracker has a second boat id number tag on the inside of the hull rain behind the shift lever bracket
spazzer
Ok thanks. I'll check there.
