Fiberglass hull, 10 yrs ago I punched through the hull while using a chisel during floor removal (to replace rotten stringers and floor), perhaps about 2 inches long (if I recall correctly from 97). My father patched this with matting on top of the split area....I want to remove this patch and fix it correctly now.
- What grit paper should I use to remove this patch and prep the area?
- What type of glass should I use to patch it? Woven?
- What should I do to the area that is split? Should I round out the ends of this tear to lower stress to prevent crack propagation??
Thanks in advance.
Thanks in advance.
