Re: Hull sealer
If the boat is leaking around the rivets then they are probably loose. You should tighten up the loose rivets before you apply a sealer. <br /><br />When I needed to tighten the rivets on my boat, I had a person hold a small block of steal against the rivet on one side while I gave a few raps with a hammer on the other side of the rivet. Worked pretty well for me. Almost completely stopped leaking. I didn't apply a sealer, so it still leaks a little.
