Humminbird 595c
rdny041285
My fishfinder every once in a while will just start reading .6 feet for no reason at all....even when im in over 100 feet and no waves to pull the transducer out of the water... then it will start bouncing around with the depth...usually will go back to normal eventually....is there something im doing wrong? i had the same issue with the last humminbird fishfinder that i had...please any help would be great...not good to be out on the ocean having these issues.
Nighthawk
Re: Humminbird 595c
Where is the transducer mounted and is this occuring when your engine is running?
rdny041285
Re: Humminbird 595c
i will take a picture later of where it is and post tonight...it screws up whenever....running motor or off and drifting...whether there are 8 foot waves or flat water.
