Re: Humminbird 998c SI false shallow water readings????
Originally Posted by imported_John_S
Didn't get to my menus last night, but looks like you went through them all. The S/W is at 5.4 now. I recommend updating. If you have another unit and communicate via interlink, they both will need updating. Follow the instructions and you should be fine. I have probably updated my 798 3-4 times, and the 797 before that, a couple of times.
-Plug into good power source, power on.
-Reset to default parameters
-Insert SD card with new S/W.
-Answer prompts.
-S/W Loads.
-When complete, power down.
-Power up, and change parameters back.
Scheduled to do some mapping this AM. Will try some shallow water recording with some of the suggestions mentioned earlier. Time allowing I'll try the S/W update this afternoon. Thanks again.
Tried the "fixes" earlier........didn't work, the readings in the digital numeric read out and chart were different. Did the S/W update now both readings are the same. I'll check later in HBPC to see if the track plot data recorded to the SD card is showing the correct readings. Thanks again, John_S. Still can't believe the updated S/W would have made the difference.
