Humminbird Fish Finder
kcfromohio
I have a Matrix 12 fishing system from Humminbird. I have the base mounted on my dashboard. When I click the unit into the base, It goes in smooth and locks. When I try to remove the unit from the base,The release button is very hard to push and does not always disingage the unit from the base. As a result I have damaged the pivot point on the base. It seems as if the release button is not working properly. When not on the base I can only depress the button about 1/16 to 1/8 of an inch and it is very hard. It seems like trying to spray a can of wasp killer without removing that little plastic trigger guard.
I tried finding a Humminbird forum but I had no luck with that either.
Any Info and input would be helpful and appreciated!
TerryMSU
Re: Humminbird Fish Finder
Push the finder into the boat. That will relieve the pressure on the latch, then pull out on the finder and it should pull off a little easier. Try some lubrication on the latch. Mine requires a little effort, but at least it will not pop off when I are not planning on it.
TerryMSU
rfdfirecaptain
I have the exact same problem with my Humminbird 797 unit. I don't think this is random because this is my second Humminbird that has had this issue. Thanks for the suggestion. I will try it tomorrow.
Rick.
Don't have the problem with mine. You should contact Humminbird customer service. I have found them to be very helpful, Much better than most customer service dept's. Best of luck. Rick.
kcfromohio
I contacted Humminbird. They said since my unit was a year and a half old, it is not covored under warrenty and I will need to buy a new base mount. The little plastic base mount costs 50 bucks. I told them that is a little steep. And a new base mount will not fix the problem with a faulty release button on the unit. Their reply to me was, "Sorry we cant help you!"
@Rick,,,, We must have talked with two different people.
I will figure something out, I can make my own mount somehow! They don't call me MacGyver for nothing! (and no i'm not going to use duct tape and a coat hanger)
I'm thinking a permenent underdash mount.
NYBo
The instructions for my 385ci state that the release requires significant pressure to disengage the unit.
kcfromohio
NYBo, describe significant pressure. I'm 6 foot tall and weigh 190. I'm in great shape! I think my 130 pound wife should be able apply enough pressure to remove the fish finder! She has no problem with her GPS in her SUV!
NYBo
I guess they made it hard to remove so the unit won't disengage while underway in heavy seas.
