Humminbird Helix 9 GPS
Hofty
Purchased a Helix 9 with a "No GPS position fix". The prior owner said he had the unit checked over by an approved repair facility and they need to replace the Board. The boards are supposedly $500-600 plus labour.
Does anyone know if it's possible to purchase a "Humminbird AS GPS HS precision GPS receiver" and make use of that as an alternate GPS or does the fish finder require thr internal GPS to work?
I have tried all the usual "update firmware" and "factory reset" to troubleshoot but it's likely the GPS receiver on the actual internal board.
Thanks in advance.
dingbat
Thanks in advance.
If your unit supports it, looks like the antenna you need is the
AS GRP - EXTERNAL GPS RECEIVER.​
Of course, you will need to install a NMEA 2000 backbone to support it
Hofty
Would this unit satisfy the external GPS?
dingbat
You have it backwards. Will your unit support the antenna?
Communications and power are the issue. In my world (Garmin) pucks are NMEA 2000 compliant and would work with any NMEA 2000 compliant head units. Have both Garmin and Lowrance peripherals on my boat
Not a humminbird guy. They games and their technical documentation is lacking to say the least.
Need to see if the two units are compatible. Suggest you dig through your operators manual to see if it support a remote antenna
dingbat
Does not appear that gen 2 units support a remote antenna
