Hummingbird problems.
zach103
The Larson came with a Hummingbird 100sx. it worked fine last year but it was only in the driveway last year.. now the other day i tried to turn it on and it would just beep. i filepped the switch and tried again.. it came on but only went to the demo screen where i can adjust the settings.. it wouldnt let me go anywhere else. than when i went out on the water the other day the screen wouldnt even turn on. just more beeping when i hit the button.. any idea what could be wrong..
NelsonQ
Re: Hummingbird problems.
zach
when I installed mine, I hooked up power only. Before the transducer was installed, it went into demo mode.
Try to unplug the transducer and see if it works in demo mode alone. if it all works out, replug the transducer and see if the problem re-occurs. If so, bum transducer or a short in the cable?
If the problem still happens, you may have a faulty head unit.
zach103
oh also . light won't turn on.. is there something i have to change to get that to work?? something inside the headunit....
and now i have no power . no beeps nothing.
NelsonQ
Most likely not your transducer that's the problem.
Have you verified a good, clean power connection?
If so, do you have a friend, etc that you could connect the head unit to their Humminbird setup (a friend of mine and I have different head units but the mount and plugs are the same/interchangeable) so it would be a quick test to validate but I suspect you have some issues with the head unit itself.
Lastly, you could contact Humminbird directly and see what they say. I'm not sure they'll be able to help or will repair as it's a discontinued legacy product.
