Hi there,<br /> I will be getting to my stand via my 1976 merc 115 with thunderbolt ignition system. This means early morning starts & near freezing starts. the problem I have had this summer is that my start disengages. When trying to crank the motor the starter engages & cranks the motor fine, until the motor fires up & tries to turn over. When the motor first get any fire, the starter gear drops down, continues to spin but is no longer engaged to the flywheel. I have a good battery (540 cca), full charge. I have cleaned & lubed the starter shaft.<br /> Any Idea as to what is going on?<br /><br />also if you guys can lend any tips on cold starting this bugger.<br /><br />Tom
