Hyd Line Replacment On Power Trim
23SEARAY
How are the hydraulic lines on a MercCruiser replaced? It appears that the the engine has ti be pulled. Another possibility is to remove the Hyd manifold on the gimble housing? I couldn"t find anything in the manual
Re: Hyd Line Replacment On Power Trim
Ayuh,.... The Hyd. Manifold will drop down enough to unscrew the old,+ replace with new...
23SEARAY
Thanks for help, I"m on my way to fix it.
Bt Doctur
Go to the Adults section and download the merc manual,it`s in there
