Hydralic engineer question: pump dynamics johnson/evinrude impellers
robert53a
OK I have a 3hp Johnson that has a 3 vane impeller the 4hp of the same year has a 6 vain impeller both use the same keeper and ride in the same size cup. what is there difference? volume verses pressure? I'm just curious. Thanks
boobie
Re: Hydralic engineer question: pump dynamics johnson/evinrude impellers
Got some model #'s of both of them ??
Haffiman
Somewhat a combination of a lot of wanted effects.
You may increase number of wings to gain a higher pressure at a lower rpm.
Not quite sure of which engines you are talking about, but the 4 hp might have a higher exhaust back pressure compared to the 3 horse engine. This may call for a higher pump pressure to ensure same volume. The same for engines with pressure regulated cooling systems (spring loaded thermostat/poppet valves etc) which requires a certain pressure at a certain rpm. On inboard engines I often installed 12 wing impellers on engines with an exhaust back-pressure problems to avoid the impeller wings getting 'blown' off. Another way to go is to make a higher impeller with less diameter like Mercruiser did on their drives long time ago.
robert53a
Thanks guys. This was just a question I had about a 1990 johnson 3hp I have that over heats on the head, I think. The temp gun says 170 degrees in close to the plugs when idling and about 150 degrees 1" away from plugs. This seems a little hot. The lower has a new impeller and no wear on the cup or plate. This maybe normal. i just don't want to bugger the engine. Thanks. The reference to the 4hp came from my 89 service manual. It's a 4hp deluxe with a thermostat and six vane impeller.
