Hydraulic cylinder rebuild
Captndrydock
"If there are pumps on Ebay and they are Chines made, do not buy them!
Starters for Chrysler/Force and made in China are crap, but cheap."
Trouble is just about anything new is built in China.
If it's rebuildable??? Then use OEM or Factory parts from a Mercury dealer.
Those parts are probably Chinese too but held to a higher standard(better parts),
After a little digging and asking AI, sigh, yes...China parts can be both good and bad quality. The better quality parts have ISO 9001 certification. So I asked it to search for ISO 9001 certification for DB Electric and apparently they use the higher quality parts.
Here's what AI "said":
DB Electrical has stated that it uses suppliers with ISO 9001 certification to source its parts, including seals and O-rings. The company specializes in automotive and equipment electrical parts and monitors the quality of its products to meet or exceed OEM specifications.
Captndrydock
View attachment 410679View attachment 410679
getting off the end caps (not easy)
taking apart the piston and ram rod from a set of freshwater used cylinders I bought to replace all the seals
original cylinders with re-done seals on freshwater used internal parts....
PS
the original OMC seals lasted 36 years before they started to leak!
Thanks for the pics. 36 years, hmm... I must say, I have tilt cylinders that don't leak, but they're about 45 years old. I assumed they would be leaking soon after I started using them, but I do wonder if they are deteriorated or not. The motors they came from seem to be low hour motors.
