Re: HYdraulic steering extension??
Alwims,
The same can be said for the connections at the helm and at the cylinder. His existing hoses would not be touched, the "splices" we are talking about are threaded components, not swaged. Just as your hoses are threaded onto your helm and cylinder. When the 1000 PSI tubing is used on I/Os and I/Bs, it is secured with compression nuts, just as I have described here.
Both the hose and the tubing are rated at 1000 PSI. Both swaged fittings (hose), and compression nuts (tubing) are standard Teleflex installation methods...
