Re: Hydraulic Trim on 1991 Evinrude 150 HP
Hello Mumblerone,<br />You sound like someone who is experienced with Johnson Tilt/trim problems. I have an 1986 115 Johnson V4 where neither the trim or tilt will<br />go out (up). Motor runs ok in both directions, but motor and pump just whines when I try to go up. Fluid level is ok. Can you help narrow the problem?<br />Thanks.
