Hydro electric shift Johnson for the 65hp and 100hp motor I have. Work around, simple relays and Arduino setup.
ic2droids
Here's pictures of my setup. I have a 65hp, 100hp and a 140hp Johnson... On my 65 hp I put the Johnson electric shift dumb 12v relay switchs and I drilled a hole and put in a screw in my throttle lever so it will only go from neutral to forward on both my boats.
On my 100hp (on my pontoon) I put in my Johnson electric shift smart switch using Arduino. ( I put all the electronics in a waterproof box mounted inside the colsole then put the 3 buttons up on my console and drilled some holes. The Arduino I it plugged into a DC-DC 12V to 5V 3A Converter Step Down Regulator Module. This Step Down Regulator controls my 5v relays and my 5v Arduino.
If anyone would like to checkout the video I posted last year when I built the smart switch check out my YouTube Video. It was basic...
I posted the code with the original breadboard setup.
Johnson electric shift dumb relay switch
https://www.dropbox.com/s/e5begoif1f...witch.jpg?dl=0
https://www.dropbox.com/s/0nbhgyv4yw...duino.jpg?dl=0
Link to the Arduino Code and Video of how it works with downloadable code.
https://www.youtube.com/watch?v=QjznLCX-o3g
jbcurt00
IC2Droids here a new topic w your work around
Please dont post the same thing in multiple places
Dont post to inactive topics, after 90 days w no new posts, consider inactive topics closed and for research only, not to be posted to.
