hydro electric shift need help
crownlover
I have 75 85 hp v4 johnson hydro electric shift. the shift switch in the control box broke today and boat is stuck in reverse. i cant seem to find a replacement part for it so i was wondering if i could wire up a three way switch and change gears with a toggle switch.
Barnacle_Bill
Re: hydro electric shift need help
You need to recheck the year of that motor. Either 1972 or 73 was the last year for electic shifts.
crownlover
is it possible i have 72 model controls on a 75 motor model number is 85esl755
ohioriverat
Something is wrong because i had an electric shift and when no power is to the switch it would be stuck in forward gear, it's a failsafe to get you home. Yes of course a toggle will work, must be able to handle the power.
jayyyy
X2, Seaway marine in WA might have a push button switch.
crownlover
got dp dt switch from auto part store and she shifts like new. pretty hard to figure out the wiring but it is possible.
crownlover
i think i have a 75 engine with a 72 lower unit. not sure how to no for sure
