Hydro-electric shift question?
kax2000
Can this cause the hydro-electric shift not to work?
50273C
kax2000
Re: Hydro-electric shift question?
L/U removed and service manual on the way.
Before pressure testing the l/u to fix leak..... I was going to replace the oil(type C) and connect a drill to the drive shaft, apply voltage to leads to test shifting function.
Is this a good idea for testing shifting/solenoid function....or is there a better/easier way?
keykev
applying voltage to leads will work, but you can turn shaft by hand and achieve the same results.
Faztbullet
After you repair it you need to flush pump. I myself use ATF to flush it and you will need a drill to spin shaft to get the pump pressure up as hand turning will not work..
kax2000
I am using a loose fitting metric 12 point socket to turn the drive shaft.
Will this socket fit a '72 Evinrude 50273c?
Part # 0316612
