Re: Hydro lock, what to do afterwards?
I am having the same problem with VolvoPenta 5.7gs and could use a little assistance.... I had a situation on the lake(freshWater) where at some point in the day the boat would not shut off (dieselled) until I turned the key back on and then back off. Only happened this one time... but later once we stopped the boat for a little swimming and tried to start back up, it hydrolocked and sheared off a starter bolt... have fixed that already(twice now) and had water in most all cylinders, both sides of engine... I was reading a post that said the dieselling could cause water to back up through the exhaust... I have checked the manifolds and risers plus gaskets and all appear to be ok... also have checked water in the thermostat housing for bubbles when turning over the engine to try and prove out if a head gasket was leaking and all seems ok there.... so I am hoping the engine and all components are fine, just got water in through the exhaust somehow... possible? Thanks !!!
