scottberry
Thread starter- Joined
- Jul 3, 2009
- 20
I have a 5.7 mercruiser that is having a hydro lock issue. Last week after a successful day of boating we were sitting in a cove swimming. A few big waves came at us and hit the boat from behind. I have through hull exhaust so there is a possibility some water could have passed through.
A little later when I went to start, the starter grunted and then was spinning but not engaging. I had to get towed back, but at least it was the end of the day.
I started breaking down the issue and removed the plugs. A little water dripped out of the center two cylinders on each side. I turned the motor over and a little more came out but not a significant amount.
After replacing the starter and plugs and putting new exhaust flappers in the the through hull pipes, it started right up and ran perfect in the driveway. It started and stopped several times with no issues at all. I took it the lake to water test which was about a 30 minute drive. By the time that I had launched the boat in the water, the starter was binding again. I pulled it out of th water and removed the plugs again. As I turned it over, a little water came out again. Mainly out of the two center cylinders on each side.
So if it appears the motor is running fine, how is the water getting into the cylinders and causing the motor to hydro lock and bind up the starter.
When I first checked the oil it was fine. Now after running it, there is a slight milky texture but not that bad. It is not all foamy in the valve covers and the dipstick does't look like a vanilla shake.
Any thoughts or suggestions??
Thanks
Thanks
