hydro tilt wont release
pappamike
I just boat a new Yamaha,25 hp,4 stroke,tiller,el. start. I am 200 mi. from the dealer so I want to try here for my answer. The engine has the gas support lift cyl. I took the boat out for the low speed break in and tilted it up when I got done and it sat for a week. I tried to lower it today but it will only drop down about 4 inches. It's almost like something is stuck or the gas in the cyl. is equalized. I can raise it up all the way but it will only go down 5-7 inches. This leaves the prop only in the water 2 inches. I can move the lock lever to the lock position and it locks the motor in that positio,however when I move the lever to the unlock position,the motor can be raised up but only drops down about 5-7 inches and stops. Help please, I dont want to have to make the 400 mi round trip to the dealer.
99yam40
Re: hydro tilt wont release
gas support lift cyl is new to me, never heard of that on a motor. Only power tilt and trim
Could you post your model #
maybe you have manual tilt and you have it in shallow water drive
Read your owners manual
boobie
Call your dlr and ask him or else Yamaha customer service. Must be something new cause I never heard of it either.
