Hydroelectric shift problems
pcazzola
I have a 69 Johnson Hydroelectric shift and motor(# 85ESL69). I finally got my motor started but when it started it was in full bore forward even though the stick shift was in neutral. How can i get it to have r and N. he boat sat for awhile and im tring to go fishing but at this point if im in the water i have to be pointed out at the lake or ill just take off!! A very novice boater needs your help!!
Drowned Rat
Re: Hydroelectric shift problems
Hi USMCGUY. Use the search feature to look for hydroelectric shift problems in the Johnson, Evinrude Problems Forum. This exact issue has come up a number of times and all the information you need can be found there. If you still have problems after that, let us know. Good luck.
JB
Moving to Johnson troubles.
gary11756
USMCGUY<br />Do u still have a problem, Write back and i have a few easy test to with a 12v tester.does your control box have a warmup lever or buttons.
Walker
Try to stop the prop with a brrom stick. Sometimes a prop will turn just from the inertia in the L/U
karrick
I wouldn't advise trying to stop the prop with a broomstick. :eek: My '71 60hp had the same problem and I found a bad shift switch. If I would have stuck a broomstick in the prop I would at least be minus a broomstick and possibly an arm. Let us know if you have other probs.
