Re: Hydrofoil Sting Ray Question
If you have problems that can be fixed (helped) by adding one, then maybe it would improve things a little, but just bolting one on for the heck of it won't do anything for you. It is possible to achieve some or most of what's claimed in the propaganda they come with, but it's not just a bolt it on and go type product. To see improvements you need to have an issue it will help, then work with the setup and make adjustments until you see the improvements and also reduce the possible negative affects.
