Augoose
Thread starter- Joined
- Mar 21, 2010
- 1,245
All,
I know this may sound ridiculous, but I'm looking for ideas to prevent my 1999 Chris Craft 200br with VP 5.0 GL from hydrolock which has happened twice now. In short, I've owned the boat since 2012 and never had issues until last year. Something of importance is that one year prior I added a fiberglass swim platform which weighs about 250 lbs. I think that has aggravated the issue.
So last year we were moored off a beach in rough water. The boat surged up and down more than it has ever in chop for about 2 hours, so much that air and water were blowing through vents in the swim platform like a whale purges air and water out it's air hole. On the way home that day the boat was hard to start and the boat completely shut down while underway - a surge of water hit the stern and I couldn't start it after that. I was towed in and then drained water out of the rear cylinders on BOTH sides. Manifold gaskets were new the year prior.
Fast forward to this year and after replacing a litany of components thinking I had an electrical problem the year prior which contributed to the stall and surge of water, we went out on the water and the boat ran great on several outings.
Last week we were moored again with bad chop. Again, blow hole surges of water from the swim platform vents. Myself, my wife and my two boys were all sitting on the back deck while swimming. Went to start the boat and it was hard to start - it stumbled, coughed, and bogged for several minutes until it eventually cleared up. Seemed very similar to last year.
I'm thinking the weight of the added swim platform plus the four of us sitting on the back deck caused the static water line to drop, going below VP's 14 inch requirement. This caused the water level to rise where water worked it's way up the exhaust and into the engine. During other trips this same season with calm water, we haven't had any issues.
So here's my question - where are the exhaust passages through the exhaust on a SX-M drive? I know about the prop, but what about other areas around the transom? The exhaust bellow is in good shape with no cracks that I could see. I replaced it in 2012.
What if I were to make a sock or boot which I placed over the prop while anchored to prevent surges of water from working its way up the exhaust? Obviously I would have to create some sort of reminder procedure to prevent forgetting the boot before starting the engine. The risers I currently have on my manifold are already pretty tall, so I'm not sure a taller riser is the answer.
Thanks
Augoose
Thanks
Augoose
