I wanted to revive the thread with updates on the issue.
So I replaced the manifolds and elbows with another set. Replaced the flappers also put everything back sealed properly.
rebuild the carburetor with a kit from Mikes Carburetor which seems to be the most complete, also bought and installed a brass float.
everything is back and I started it.
It was running great few adjustments here and there and THEN I noticed that no water comes out of the back of the exhaust.
I am including pictures of the hose connector.
Ok so inside I have picture of the plastic removable blue plugs one had some hot water the lower had none.
I am also including pictures from the back where the port side hose goes, and the picture of the thermostat housing.
What can I do next. I am researching where the bottle neck is. it has to be between the outside hose and the thermostat housing.
Compression was great on this. So remember the story as it initially transpired the boat was water locked and not while on water but in the parking lot. So whatever caused that might still be around.
I am looking at the water pump and I see a lot of the salt build up outside of it. Funny because it has only seen salt once. So why all of this white stuff? Is it a stuck thermostat?
