I am going to kill myself.
lakelivin
Re: I am going to kill myself.
Don:<br /><br />If this is going to be put in the FAQ section on starting problems, I'd suggest you also add the instructions on diagnosing using a test light or volt meter that you included in a previous post about the subject. <br /><br />I did a quick search but couldn't find it, probably because Don has so many posts and I didn't have time to look very thoroughly. That's the one I used to figure out I had a bad assist solenoid, and it was very straightforward even for a beginner like me. I'm guessing that way has a bit less chance of generating sparks, no?<br /><br />One other suggestion is that you highlight part of the following sentence in your instructions: <br /><br />Change: First thing you have to do is make sure all the battery connections are tight and clean. This includes the ground connections on both ends. <br /><br />To: First thing you have to do is make sure all the battery connections are tight and clean. This includes the ground connections ON BOTH ENDS.<br /><br />For some reason I have a feeling that many of us beginners may need that part hammered into us and that highlighting it might help.<br /><br />Just a couple of suggestions from another boating neophyte (I sure hope neophyte means what I think it means, lol).
KaGee
Originally posted by crazy charlie:<br /> I just saw a bright flash in the sky,I think we lost him...
Naaaaa, that was ET a week late for the Fourth of July. If it were him, there would have been a fireball. :p
Mnemonic
LOL... I sat with the mechanic yesterday... He did the exact test Don posted. I guess he just has a bigger set of balls than me. <br /><br />He verified the problem was the starter, and me and him are getting together on friday and he's gonna install it, and i'll take notes.<br /><br />The only decision i need to make is if i want the hi-tourque peanut starter or standard marine starter.
thunderroad
Glad to hear a happy ending looks possible. Just remember...a "click, click, click" heard before the engine is running is usually an easier fix than a "click, click, click" heard while it's running. :) <br /><br />Enjoy the boat, it's a cool lookin ride
Boomyal
Originally posted by Mnemonic:<br /> The only decision i need to make is if i want the hi-tourque peanut starter or standard marine starter.
IMHO, it's a no brainer. Go for the peanut starter.
Mnemonic
Yea? Whats the difference? Easier to replace if this happens again i know, but what else?
OutforFun
I have a similar issue but I don't know if it’s the starter, but who knows. I don't have much knowledge so hopefully one of you guys can help me out. <br /><br />I have a 18 ft. 2000 Maxum 1800 SR with Mercruiser 135 HP engine with only 117 hrs. I've had the boat for 3 weeks and everything was fine until this past Sunday. I had it running and everything was good except starting was always difficult at times. On Sunday just didn’t start at all. The engine turns (it makes the noise but won’t catch) and all the connectors are good, but I replaced the battery to make sure, so I may have to check the wires again. Am I missing anything? <br /><br />I have checked the starter solenoid and everything seems to be connected properly. Only thing I did was look at the wire to see if its was clean and the center wire was a little bit dirty, so I attempted to clean it and start it back up with no avail. I even took out one of the spark plugs and have gotten a replacement. I have not put it on since the boat is on the lake currently. If it’s not the spark plug what else is it that is not making it fire up?<br /><br />Thanks,
QC
bosox dude,<br /><br />You should repost as a separate thread. ;) Does not seem like a similar issue to me as your engine cranks over . . .<br /><br />BTW, welcome to Iboats.
OutforFun
Sorry, I created a new post. I hope to learn a lot about my boat.
