third times the charm
- Joined
- Jun 20, 2011
- 321
Okay, i hope i can get some answers here. I have a 1968 f-22m johnson 20 hp outboard. Just put in a new flywheel key(before anyone asked the reason the old one was sheared was my own doing). I am having starting problems. Hes is what i ahve done so far to fix my problem:
First off its been 3 years since i had tried to use the motor
I got fresh fuel this year, put in my stabilzer, the fuel is a 50:1 mix.
I flushed out the fuel lines all the way to the carb. removed the the carb, but not the fuel bowl and forced some fresh fuel into it.
MY point gap is .020, i checked it to make sure it hadnt changed. The motor ran 3 years ago thats the last time i had set them.
installed new plugs, champion j4c,
Nows here where i might be having the isues but not sure, when i put my meter on each plug boot and touch the other side to ground the top coil pak gives me a reading of 2.2 to 4 volts when i pull the starter rope. The bottom coil pak gives more of a soild reading of 5.4 volts. Not sure if that is correct. i ohmed out the coil paks, they gave me a reading of 6k. i read somewhere that as long as i was 3 to 15 k then the coils are fine. i was planning on leaving for vacation tommorrow, but not unless i have the boat. its is cruical for me to camp with the boat
HELP:redface:
